jeff...
Well I figured I would give epoxy / sawdust mix a try. I edge glued three white oaks boards together. One of the edge glued joints failed and also 1" band I glued to the endgrain.
I'm sure it was something I did wrong. I mixed up appox equal parts resin / hardner / fine saw dust from my belt sander. Did I use to much saw dust or should I have used a differnt kind of epoxy? It was Loctite 5 min epoxy like this one 5-Minute Epoxy Syringe
I had good squeeze out from the joints, so I'm confident I used enough.
Advise from the experts would be greatly apprciated.
No worries, I'll resaw the joints and re-glue with good ole yellow glue - I know that will hold.
Thanks
Thanks
