Is that the 14" model that uses a 93 1/2" blade? Delta numbers can sometimes be a little difficult to pin down, so I'm not positive, but I think that's the same one I have.
Does it have a 1/2, 3/4, or 1 h.p. motor. Mine had the 1/2 h.p., and it was a little underpowered, so I switched to a 1 h.p. Better now. If you want resaw capacity, this probably isn't the best choice. I think the max resaw is 6", and you're kinda taxing the machine at that. Adding the riser block is an option, but that causes other problems: the saw is difficult to keep in alignment.
I upgraded to a Rikon 14" to use mainly for resawing, and kept the Delta 14" to use for curved work. It works fine for that.
