jeff...
User not found
Some times I'll go ahead and use a piece of wood that may have a small check (crack) in the wood. Checking usually occurs around figure, like crotch feathers, burl, knots and on the endrgain.
DaveO showed me a cool way to fix this for good. Flood thin CA glue into the defect, thin CA wicks into the smallest areas of the crack and shoot it with accelerator that takes care of any structural deficiencies. Next as your sanding the board you'll notice the crack fills up with dust, capitalize on this with more thin CA and accelerator. continue with dust, thin CA and accelerator, till the void is full and flush with the surrounding wood. This works great and with a clear finish it blends right in because it's really wood fiber from the surrounding wood thus is about as close of a color match to the surrounding wood as as your going to get. For larger voids, after securing in with thin CA, switch to Medium or thick CA as they have more bridging characteristics, thick more than medium and medium more than thin.
Before DaveO showed me the CA thing, I used to use clear epoxy, it seemed to work OK but the CA thing is much easier and faster.
I've heard of others using coffee grounds and CA so I'm wondering what others do to remedy defect in wood.
Thanks
Thanks
