Cutlist Software
SteveColes
I have a program called Cutlist Plus. I was using it today to try to create a cutlist for some shop cabinets that I'm about to build. I entered all the materials and the parts list for one cabinet. I assumed that there would be a setting that would allow me to say how many cabinets I wanted the cutlist for. But I couldn't find it:BangHead: So I just did the multiplication manually as though one cabinet had the part count for seven. That worked, but I can't believe that there isn't a setting to do that automatically.
Cutlist users, what am I missing?:eek:
stoneskippers
John Skipper
When you enter your info ( part #, description, quantity ) then the next column is copies. This should give you a total.
User not found
Unfortunately, Cutlist Plus does not allow one to multiply at the Sub-Assembly level (which would correspond to a particular size cabinet). As John said, you can multiply at the Part level. So for example, I might name a project "Shop Cabinets" and the Component ID might be "Base Cabinets". My Sub-Assemblies will probably be things like "Carcase", "Shelves", "Drawers", "Face Frame", "Doors" and "Toe Kick". Parts are named as the pieces of each Sub-Assembly -- e.g., Single Raised Panel Doors will include Rails, Stiles and Panels. If I have four identical Doors, then I'll have 8 Rails, 8 Stiles and 4 x # of pieces to form a Panel.
For Raised Panel doors, I use the Excel spreadsheet I recently uploaded to the Download Library to calculate sizes of rails, stiles and panels. It will give correct dimensions with simple entries. For a glue-up panel of say 12" x 26", I will enter 3 pieces into Cutlist at 4-1/2" width x 26-1/2" long per door and add a note (right click on the Part #) to remind me to trim the panel to 12" x 26" when glued up.
Hope this helps.
Footnote -- the limitation of 50 parts is a minor issue; I just create another project. But, I'm not happy that both Sales Tax and Markups are excluded in the $89 Silver version -- I cannot justify the $249 Gold Edition for those features along with unlimited parts and the ability to specify multiple copies of a Project and to produce cost proposals.
cpowell
Chuck
Hope this helps.
Thanks for the excel link. Simple tool but it's nice to get it all put together for free.
Chuck
NCPete
Pete Davio
I like that tool! thanks for the link Rob.
Re: cutlist plus.... using the silver edition now... may be justifying the Gold on one of the next jobs --- imagine doing 35-40 feet of kitchen cabinets, 50 pieces at a time:roll:
