Chris, my Delta has one cast wing and the Biesemeyer plastic laminate table on the other. I see only a slight advantage of the cast wing over the plastic laminate table, if I had your saw, I would probably just put a nice flat plastic laminate table on both sides. If you are careful when you make them, you can minimize the tiny groove between the saw cast top and the attached table which is the only important performance difference IMO.
