Starting to refinish a 20 year old high-chair for my neighbor to eventually give to his daughter or son.
History: Bought at an unfinished furniture place (looks like pine). He stained it with something then he thinks that he top-coated it with polyurethane per the recommendation from the store.
I'm now scuff "sanding" it by hand with some Scotch-Brite pads (grey-coarse stripping pad and green-heavy duty pad) so most of the stained areas still look pretty good without much cut-through so I'm not being very aggressive.
1. Can I put a wipe on/wipe off oil based stain over this to touch it up a bit? This doesn't have to be a fine furniture finish for the intended use.
2. I'd like to top coat with Zinnser clear rattle-can shellac, but maybe an oil based poly would be better since the base coat is poly. :dontknow:
Recommendations and experience are always appreciated. Many thanks.
