Ok, so, for no reason, I got an idea.
If you were to do what I call "blind wedged dowels", could you eliminate the need for visible fasteners in a deck?
Bore a sloppy hole in the underside of the deck boards.
Bore a similiarly sloppy hole in the top edge of the joists.
Cut a kerf in both ends of a dowel.
Drive some wedges in each kerf, then glue and drive them home.
Am I crazy ( more than usual)?
