WTB: Spindle for pre 1957 Buffalo Forge Drill Press
Rick_B
Rick
Looking for a good spindle with chuck release nut for a pre 1937 Buffalo Forge 15" drill press. If you have something let's talk
Rick
Wilsoncb
Williemakeit
Do you know if it’s an R-8 type? If so I have this one with a J33 taper for the chuck.
Rick_B
Rick
Thanks - what I need is a splined drill press spindle. I'm going to try to get a picture posted later today.
Rick_B
Rick
So a few specifics - doesn't have to be a Buffalo spindle. It does need to be a6 spline, 5/8" diameter, at least 15" long with a spline length of at lease 6-1/2" and a taper chuck fitting.
Rick
bob vaughan
Bob Vaughan
To clarify what Rick means by chuck release nut is the threaded collar typically found spindles using the Jacobs 34-33C (633C) chuck.
This is the threaded nut for chuck release. The bearings happen to have been installed on this spindle.
Rick_B
Rick
Thanks for the clarification Bob - when I saw you responded I was hoping it was to say you had what I needed on the shelf. :). Turns out after destroying the chuck I discovered it was a 33B - threaded chuck. Not sure if the spindle came threaded from the factory or a PO got creative and put a 1/2 - 20 thread on the taper.
Rick
Wilsoncb
Williemakeit
Looks like they were $4 back in the day. Don’t know what year this was but you had to have a minimum order of 40 cents.😂
