WTB: Floor Drill Press
danceswithwindows
danceswithwindows
Looking to buy a floor drill press. Looking for something that has a 18” to 20” throat, at least 1hp motor (single phase). Would love to not have to buy new if someone has a decent one they would like to sell or get some cash to upgrade.
Thanks!
tvrgeek
Good luck. As usual, I dive deep and over-reasearch these things. My experience:
I bought what I thought would be a decent one. Delta made in Taiwan. Nope. Trash. Sheaves not round, chuck junk, and like most modern drills, the case is not split to adjust the quill play. It does all depend on what you use it for. I do as much metal work as wood. My first Craftsman was so flexible you could not use it to rough drill with a forsner bit for a mortice. I had to support the table with a jack. My Delta is only a little better. Should have bought the Palmgren as at least they published full specs. Can't justify a Nova. If only woodwork, consider a radial arm drill as it can give you the reach when you need it, but retract for more rigidity. Sure wish I had a Reeves drive.
Do think if you really need 18 to 20 as the deeper the throat, the more play just by leverage. With most power tools, you can almost buy by weight.
Sale season is upon us, maybe Griz will have some of their industrial metal working drills on sale. Gear head beasts. Of course, some 80 year old long gone name beast is probably a way better tool, but I have not found one either. Came close but the table had no lift.
bob vaughan
Bob Vaughan
If you don't mind a little work, govdeals often has drill presses from school shops.
https://www.govdeals.com/woodworking-machinery/filters?pn=1&so=&sf=bestfit&ps=24
Most likely you'll find a 20" press but it will also likely have a 3-phase motor. VFDs are cheap and simple these days.
There will be a multitude of 15" and 17" presses, but those won't qualify for your needs at all.
Below is a 20" press that a friend got for a few hundred dollars a while back. The head was lowered on the column so it would travel better. I take it that this is exactly the type of press you're looking to upgrade to.
Powermatic Model 1200. Column diameter: 4", floor weight: 600 lbs.
bob vaughan
Bob Vaughan
A large drill press should have a 6" quill throw to take advantage of the various tooling it will be capable of using.
tvrgeek
I would suggest you look at the floor standing WEN drill presses. They are solid quality at a great price.
WEN is the champion of cheap tools. I have several and am a fan, but they are cheap tools. They will have more flex, lower power, more quill slop and not as much quill throw and depending on use, not the durability.
Now that PM pictured above, yea a "real" tool. W-T, again, a "real" tool. What you don;t ever know is how they were maintained and there current slop. Bearings, quill etc. One from a school is probably less worn than one from a factory. Parts can be an issue.
bob vaughan
Bob Vaughan
Here's a good example of a govdeals drill press in Ohio. Right now less than $200.00 and it looks it has a vise with it. The surroundings look like a lab of some sort.
A 1968 Delta 20" press. Such a drill press had a list price of $7825.00 in 2005, but that has to be adjusted for today's inflation. You can clearly see these presses will be a good buy with no compromises in drill press quality.
https://www.govdeals.com/asset/1689/2372
danceswithwindows
danceswithwindows
danceswithwindows
Great thoughts all. Based on what you all have discussed and the photos shown, I think In my inexperience I am going for something that is too big for my needs. A 600lbs monster is probably wasted on my limited shop time and walk-down basement shop.
What do you all think of Grizzly for a drill press? I thought the attached might be a good deal for new
