Beginning woodworker seeks advice.
I am looking for some assistance with a mallet I am trying to build. I am generally following the plans laid out in the "Big Ash Mallet" episode of The Woodwright's Shop (http://video.pbs.org/video/2365021538/). I chose this project because it seemed like a relatively "accomplishable" project given the video and other mallet-building instructions I found on line. I should have known better.
As you can see from the pictures, the issue I am having is that once I get the mallet head down to size, the wood eventually starts to split apart. I created two mallet heads and both split. However, both heads came from the same log so perhaps the issue lies with this particular piece of wood. As for the wood and its origin, this is what I can tell you:
-I believe it is oak
-The wood is not freshly cut, but I do not know how long it had been seasoned; however, the wood did feel a little damp when I removed the bark
-I made one mallet head completely from heartwood and I rived another that was comprised partly of heartwood and sapwood (the heartwood/sapwood mallet is pictured)
-With the mallet head that's pictured, I attempted to capture the "vertical end grain," although it was not entirely possible given the head's shape (about 5-degrees difference between top and bottom)
My questions are:
-I assume the splitting is due to the moisture content and/or drying process of the log. Is this the case?
-How green or seasoned should the wood be before I start?
-Should the sapwood be avoided for a project such as
My constraints are that I am attempting to accomplish this project with hand tools and on a limited budget, which is why I am using what is basically a log that was destined for the fireplace. In the end, it looks like this wood will find its rightful home. Haha.
I'd appreciate any advice and guidance. Thanks.
Dave
My questions are:
Dave
