It's getting time to think about winterizing your pressure washer. First, I would change the oil. Consider using a synthetic oil for easier starts. (I use Wal-Mart's brand.) Run some pump saver through the pump. FYI, pump saver is a 50 / 50 mix of RV antifreeze and mineral oil. You can mix your own using RV antifreeze (which many places have on sale right now for about $3.99 a gallon) and mineral oil from Wal-Mart (paid $1.49 a pint recently.) Drain tank and carb are DRY. Ethanol fuels are **** on small engine carbs. If you can't drain it, consider some of the blue Stabil, or Star On. Next spring oil will already have been changed, so you only need to add fresh fuel and fire her up.
