update on tormrek and grizzly compatibility. After awhile of research here is what I found. The tormek planer jig will not work on the grizzly due to fact that tormek jig has its own two 12mm mounting bars and they are a different spacing apart. all tormek jigs using the 12mm bar will work on the grizzly since they use the grizzly support. The grizzly was designed by Scheppach of Germany and the grizzly is an copy of their tiger 2500. The planer jig grizzly sells for their sharpener is identical to scheppach's planer jig. This came from scheppach. If you want to really get involved you can drill and relocate one of the vertical mounts on the grizzly or cut off and reposition one of the 12mm supports of the tormek. I have decided to go with the grizzly. If you translate the cost of euros to dollars and the shipping involved the grizzly price is almost identical. That,s a mouth full.
FMAC
