jeff...
Quick question - I would like to know when edge routing a curvy rail to accept a panel, do you route the grove first or the roundover? I can not use a fence on the router table because the rail is curvy so it'll have to be pilot bearing router bits. If I route the 3/8" roundover first then the pilot bearing for the 1/4" grove cutter won't remain consistent on the edge because it's rounded over. If I route the grove first the round over bearing wants to ride in the groove :argue:. It' 3/4" stock - if it were just a little bit thicker like 7/8" or an 1" my problem would be solved. Do I need to spring for one of those fancy cut both at once profile bits and hog it all out at once :icon_scra?
Kinda like the chicken and egg isn't it?
Thanks
Thanks
