What is the best way to remove router burn on an inside corner
mquan01
This is about a 7/8" radius, solid maple. I spent about 15 minutes on it and got nowhere. What would be a good way to clean this up? I tried a Dremel sanding disk, but that didn't make any impact either.
Graywolf
Board of Directors, President
Richard
You may just find the burn is deeper then you think. That said, you may have to remove more material to remove the burn, possibly more than you want.
Henry W
Henry
I have, at times, used the router bit itself as a scraper; I hand held the bit. That was on a profile burn, on the exterior, not the interior. Nevertheless it provides a sharp scraping edge that will fit the profile and the space.
Your results may vary.
Henry
red
Papa Red
Red
I'm with Henry on this. I use the router bit as a scraper and it has worked beautifully every time. Good luck.
Red
BKHam
Bradley
Red
I'll have to try that one Red, really good idea.
i get burning on the finger holds on the occasional cutting board i do, i use a corebox bit which seems like what mike used. I found the dremel sand paper mini spindles to be ineffective. however the dremel can work, I recently bought some dremel abrasive wheels that work pretty well. fine abrasive cutting burr's work as well. for the price of one kutzall you can get all of these:
[FONT=&quot]http://a.co/dAZoJ9U
[/FONT]
