In July I asked about what glue to use in repairing a separated finger joint in the pedestal base of an Ekornes chair. Phil S and Bill Simmons recommended using System Three T-88 Structural Epoxy. I followed their advice and thought I'd report back having now just finished the re-glue which is still curing but looks like it will work out just fine. I had a couple of "ah hahs" coming out of this effort that I thought might be worth sharing with some pictures.
I made up a simple caul clamping arrangement using pipe clamps and 2x4s that I'd cut coves into to match the radius of the base:
I thought the side-to-side clamping pressure would be all I need to pull the joint together, but apparently I should have added clamping along the other axis as well. You can see that the joint pulled together tightly along the inside edge, but is slightly open along the outside edge. My assumption is that the clamping pressure on just one axis slightly spread the base open causing that outside gap.
Tight inner circumference joint:
Slight open in joint along the outer circumference:
So, if doing this again, I'd know to added clamps along BOTH axis to keep pressure more evenly distributed around the circumference of the pedestal base. Thankfully, the T-88 epoxy seems to have good gap filling properties!
My other take-away from this project is to be prepared to thin the epoxy if needed and to have some lacquer thinner on hand for that purpose. The T-88 mixed up moderately thick and I had to work it into the splines with a brush to get coverage all the way into the bottoms of the spline joints. A very slight bit of thinning may have allowed the epoxy to flow more easily into those narrow spaces.
Thanks for everyone's contributions! Hope this may help someone else.
