Well, its IN the shop.......
KenOfCary
Wooden vise screws would be a neat application, but I'm not sure how you'd do the inside spiral for the receiver. But maybe I just have no imagination. Wonder how Lake Erie does it.
Board of Directors, Secretary
Simply make the screw on the lathe and use the screw to create (cut the threads) the nut (putting a cutting tool of the correct shape into the helix)
C
chris_goris
Wow, that's a beast, already assembled and delivered on a pallet jack too. What does it weigh? Just curious. I couldn't find it in the Laguna CNC router lathes and it's probably an older model.
Its about 1200# Laguna still makes several versions of it, they call it the Laguna Turner.
kevin waldron
Kevin
Laguna will also make you a machine more or less custom.... ours is 98" in length with 24" diameter turn capability. We also have a 4th axis that sits on our large 5x12 Techno machine with a 10' length by 20" diameter. So these kinds of machine are available from many makers. Size and weight can be made to order for most makers.... in reality stock deflection is the enemy of maximum length. Square you stock today for milling tomorrow and I'd almost guarantee it want be straight and parallel the next day and yes if you oversize the material you can always compensate just be sure to not make exacting measurements if the material is to be used a day or more in the future.
We use Rhinoceros for our Cad package and Rhinocam for our Cam Package and we typically make bed post including the mortises in one piece materials either natural or laminated. Aspire will work for most common things but the more complicated the project the more needs in your Cam Package... (we do own a license of Aspire)
skyline933
I'd like to spend an afternoon making some of those "do nothing" parts. And being able to "wrap" a design like that vertical florish around the cylindrical object. Lots of maths going on there.
C
chris_goris
Me too Jim! one of these days when the paying work stops!
