Waterborne Finish over oil based stain
dancam
Dan
I've ordered some Target USL waterborne lac and was curious about what I can use for stain. I have been using water soluble dye recently and have been happy with the results. I do have a stock of oil based stains and was wondering can I use the target spary lac over let's say a Minwax stain?
Any advice would be appreciated.
Thanks,
Dan C.
John Reeves
John Reeves
Dan,
I do not think that I would do that. Call Target and ask for technical support to make sure. I think you will need to use a water based stain.
You can spray the Target over the WB dyes without issues. For that matter, I have taken to adding the dyes to the USL and spraying it as a toner and then clear coating. It has worked very well with no splotching for me on pine and maple (hard and soft).
As for the oil based stains, I haven't done it, but I have sprayed USL over BLO without any issues.
You can easily spray a water-based top coat over a oil-based stain as long as you let it cure fully. I just recently did it with Varathane oil-based stain and GF Polyacrylic as a top coat.I gave it about a week to cure up right.
dancam
Dan
I checked out the Target website and also their user forum and it seems there are positive comments about the ability to use the USL over oil based stains. The major caveat is to let it cure at least 48 hours.
I also posted a question to Jeff W (head tech guy at Target) asking the same question.
I'm waiting on the delivery of the USL and I'll test drive both the Earlex 5000 and the waterborne lac and post a review.
Dan C.
rbdoby
Rick
I spray WB poly over oil based stains a lot. Just give the oil based stain ample time to dry completely. Usually 24 to 48 hours.
Rick Doby
John Reeves
John Reeves
Dan,
I have spoken with Jeff Weiss several times but I have not gotten him to respond to email. You will probably have to call him, ask for technical support.
They moved last week and are ow getting settled a bit more.
