Wanted: Onsrud Overarm Pin Router Model 2003 Operating instructions.
Thanks. I've explored both of these sites but infortuantely they don't have the basic info I'm looking for.Not exactly what you want but here a couple links that will help with some of the info you need.
Inverted Router Demo Videos by CR Onsrud
www.cronsrud.com
What "basic info" are you looking for that is not in the manual for a similar model from the same company?Thanks. I've explored both of these sites but infortuantely they don't have the basic info I'm looking for.
and it is probably still under copyright. If so, making you a copy would be a copyright violation.I have. They want $65.00 for it.
that seems reasonable to meI have. They want $65.00 for it.
Thank you. I appreciate the information.I'll touch on a few things. The foot pedal on the one I use is just up and down, no adjustment. There are 3 depth stops on the machine. usually use at least 2 stops for 1/2" to 3/4" deep cuts . up cut bits tend to loosen in the chuck and wonder up into the cut. Keep the part moving as the bit comes up. this limits heating up the bit. keep the cut speed (moving around the cut) fairly brisk, again limits heat build up. Vacuum forms are really nice and pretty easy to make. really hold piece secure. If you are routing large tops or some such run air channels in the jig for better vacuum holding power. If you have parts that have waste that can be cut off, templates with screws work very nice. The dust collection work very well on these machines so be sure to have dust collection hooked up. I can send pictures of some templates if that is helpful. Watch out for the pinch points inside the machine when making adjustments. when using the stops have something to to stop the lever from going to other stop settings that are not involved in the part you are working on. Check for play in the pin. any play translates to the cut. Just a few things I could think of at the moment.
