USA Made Planer - $500 (Greensboro)
Martin Roper
Martin
Not mine, etc.
RBI
Henry W
Henry
Appears to have VERY similar 'bones' to my Belsaw planer, except it has fewer chains exposed.
Not a lot of info in this CL post - like the electrical requirements?! CL poster is assuming you will do web searches I guess. Online manual says 1.5 hp motor, 23 peak Amps; manual suggests it's capable of molder and sander operations too. I don't see the motor underneath the way my Belsaw has it, although I expect it is there. My Belsaw is 220V motor (HP?).
Likely a lifetime tool (worthy of fitting a insert cutter head into if the width capacity will work for you).
Langd002
This looks very similar to my 1980's Woodmaster 712 inch planer. My Planer uses 230V/20amp. Woodmaster Tools is still in business.
