Hey Folks, it's been awhile since I've done a WIP series so here it goes. This project is a large Cherry Sideboard that will have tulip marquetry on the 2 center doors.
The 1st week involved drawing out a full size layout of the piece as well as processing and selecting the lumber for the case. The Cherry for the carcass is from a matched set of boards I bought from Mike Callahan 3 or 4 years ago, and the top is going to be a single board (yep you read that right) that I purchased from Rick up at The Woodworking Source with this project in mind about a year ago.
Here's the initial design sketch:
Here's the full size template:
After letting the cherry acclimate to my shop for a couple of weeks I began to process some of the case pieces this week,
1st was the legs and the front lower and upper rails:
Then I went ahead and cut up the board for drawer fronts (it's overthick for the 3/4 drawer fronts-more on that later) Note here however that this board was 16" wide so the drawers should all have grain continuity as well as be perfect color matches
and then to round out the week, I got the side and door plywood cut and started to tongue and groove them to apply solid wood edging. These pieces are going to be veneered- the sides with solid wood ~1/8 thick and the doors with the veneer with the marquetry design.
That's it for this week, next week I'll start the carcase joinery for the front, make the side panels and make the frame and panel back (if all goes as planned)
