Untrustworthy
Thought I had tuned up my TS, but cutting some 8/4 walnut, I was getting a bit of tear out on the back top.
So, checked with my gauge. Looked to be within 2 thou front to back on the blade and blade only out by 1 thou.
Huh? Then I noticed a variance. The expensive flat tip I got for the dial is not flat. HUGE error. The idea was it should register the highest point of a tooth giving the maximum error measurement against the blade. Total Chinese crap. Back to the pointed tip and sure enough, my top is out by 5 thou.
Nifty simple miter gauge. My Osborn seems to have too much slop. The detents are right on. Holds measurement and bar adjustment great. BUT, the center bolt is too sloppy. Over a degree slop. I am thinking how to fix that. Maybe with a tapered bearing and a stack of bevel washers. Makes me wonder as I was considering an Incra 1000 but how do they keep the play down? Maybe just a nylon sleeve?
Trustworthy.
I did get a precision calibrated square. With just a few strokes of sandpaper, my speed-squares are within "no light" of square. I was surprised my cheap protractor was on. Both my igauge combos are square. A tiny tweak to the left 90 stop on my Lyon trimmer and it is dead on.
So, off to re-square my TS top to blade. Again. Thinking how to modify it with either a cam or bolt to give more precise movement over a "whack" but iI shoudl only have to do this again once, so probably not worth it. My contractor saw had a cam and I understand SawStop has positioning bolts.
Trustworthy.
