TopTech TT-C50-MHP2 Motor
patlaw
The fan motor failed on my heat pump. The company that replaced it installed the wrong one. After finally realizing what the problem was, a different company installed the correct one. Please let me know if you can you use it. It was working fine when it was removed from service. The run capacitor is not included.
eehite
Everett
Pat, I hope I'm not too late. I've been lurking here but finally made an account! I could definitely use a motor for a project I'm working on.
I'll be in the Triangle this weekend to grab an anvil and could get up with you if that would suit.
Thanks!
Everett, Greenville
eehite
Everett
Vevert remember it will likely be a 220v motor
I'd guessed it might--fortunately my application can take 220vac in, because the DC supplies I'm using have a wide input range.
Thanks for the heads up!
