I'm pretty happy with the way they turned out so I thought I'd share.
They're not as hard as I thought they would be.
First I cut the slot in the case side:
I'm using a 1/2" DT bit to make a 5/8" slot so the distance between the guides is the diameter of the router base (6") plus 1/8" and the side taper so the bottom is 3/32" wider than the top.
Then I cut the shelves too fit the slot:
I taped a 1/32" wedge on the back edge of the shelf to create the taper and (after a bit if fussing with the bit height) routed away.
Here's the fit:
The shelf slips in easily to this point and then you just bash it in from there!
pete
Here's the fit:
pete
