You know this has been an interesting read about the different views on using biscuits.
I guess that all the panels that I have glued up and edge joined using biscuits to align the surfaces, I have never run into the problems that some of you have.
I am scratching my head wondering why.:eusa_thin
Whether it's gluing up panels for cabinet doors or gluing up table tops for customs desks I have always used biscuits.
Is it cause I allow suffcient time for drying/curing of the glue, clamping pressure, etc? I'm not sure.
I used to not use them, but would run into problems with the joining surfaces flexing just enough that it took alot more finishing work to work them out.
I do have set of router bits that are designed for edge joining glue ups. However I personally wasn't really impressed with them over a large surface.
Facing out the ends/sides of plywood with solid wood they worked decently.
I too have learned about clamping pressure. A while back someone posted the clamping pressure required for wood working glue.:icon_thum
Man I was putting way too much pressure prior to that read.:BangHead:
Now I watch the joint, when it closes up and I wipe the glue off. I look for no gap then I back off. Wait for just a bit then reapply pressure just til it's tight again without over doing it, as to cause it to bow.
As far as line up: set out your boards however the grain and your preferance is. put all the edges together, then using a straight edge, mark a straight line across every joint (indexing line).
As other have said if it is a larger surface do your panels in sections.
Align the indexing lines with the indexing line on your bisuit jointer. Make your cuts.
Apply your glue as normal, don't forget about the pockets for the biscuits.
alignment then is easy. If the bisuit jointers is set for the specific thickness of your lumber and you are right on the indexing line, then I don't see the problem with alignment.
We used to use basically the same procedure for aligning trouble some counter tops pieces (inside the miters). So that the edges once clamped where virtually non existant.
like I said this has been an interesting read. I am always learning and very open minded. I would be interested in hearing the problems others have had and why.
