Is it this one?Oh, the Jessem guides are great, but only for cuts that fit. I just got a set of the green foam finger thingies and will give them a try.
I am not sure I understand what you mean with "...only for cuts that fit."Oh, the Jessem guides are great, but only for cuts that fit. I just got a set of the green foam finger thingies and will give them a try.
Only hic-up on the C-14 is the quality of the guide bearings. Just watch yours so you can clean and lube them until you get fed up and put some Timken or NTK in it.Chiming in on Harvey.
I'm a fairly new owner of a Harvey Ambassador C-14 bandsaw and am very happy with it. Based on its robust construction, weight, fit, finish, hardware, adjustments, customer service and so forth, I have the strong sense that their table saws would impress as well.
Another thought...
I'm the camp that thinks that a router table embedded in a table saw extension surface makes all the sense in the world--until it doesn't. There's the fence issue as well as the easily foreseeable frustration of having to change setups. If you have a critical setup for the routing function and then need the table saw, you have a Shopsmith situation. Shopsmith too made all the sense in the world--until it didn't. A lot of people produce truly admirable work on a Shopsmith. However, it takes patience and planning to work efficiently with a multi-function tool swap system like Shopsmith. I think that a router table / table saw might produce similar conditions and frustration. As such, I favor machines dedicated to their primary function.
Of course, budget and space are often drivers that each of us wrestles with when machine decisions.
Good products and far cheaper, but the BOW work a little differently due to the cam design of the finger supports. At least that is what is said.Not to digress, but since we already did these have done well for me.
Very flexible - they can be stacked vertically and the board itself can be reversed in the carrier to change the offset from the fence. Another neat feature is the first feather is slightly shorter than the rest so you can use it to set the offset from the fence (and presssure) more consistently. Solid construction - good for ripping hardwood stock but perhaps not best for smaller or more delicate work.
Im pretty sure the Harvey is a Grizzly, Grizzly has been around much longer. Probably both come out of the same Chinese plant, hence so many similarities if they exist, Im not familiar with either however.Pretty sure it is a Harvey.
