Suggestions for cutting aluminum
Dreuxgrad
Ed
I have eighth inch angle that requires a slot in one wing.
Wondering about using my scroll saw to open it from the drilled holes.
Suggestions for blade and speed would be appreciated.
Thanks, Ed
Size of the slot ? I would if possible use a 7 or 8" finish blade(50-60 teeth) on a table saw. Works well. If you are worrying about the chips, just put a piece of wood or ply on on top, then cut.
Dreuxgrad
Ed
Just to enhance the response, it is a cross cut for the attachment of a magnifier on one of the two inch legs.
I'm making the cut-off jig from Patrick Sullivan's YT vid
Dreuxgrad
Ed
Tried cutting al years ago and had a piece embedded above my chop saw for quite a while. Don't know if a shield would have stopped it. PS- wasn't using the prescribed blade.
mpeele
michael
How wide is the slot you are cutting. I use my router table to cut 1/4" slots in 1/8" aluminum angle with a 1/4" spiral router bit. I do it in 2 or 3 passes.
