I'm building a massive woodworker's workbench. I'm taking design elements from 3 different benches in Christopher Schwarz's books and a set of plans from Benchcrafted. My preferred joinery to attach the top to the under frames is to cut tenons on the tops of the legs, insert them into mortises cut into the bottom of the bench top, glue and draw bore the tenons tightly into the mortises.
The dimensions of the legs from 3 different plans are all within 1/2" of each other on width and thickness--~5"W x 4"T. Meeting the thickness with the lumber I have on hand will require laminating up 3 separate boards. One set of plans specifies this, and utilizes a hack I would like to use. The outside boards are cut ~2" shorter, so when a leg is glued up the longer center board automatically becomes the tenon. Seems like a smart way to do this step, so I would like to do my joinery this way.
I can mill down all 3 boards equally, which will make the tenon thinner but will adhere to the standard M & T formula of the tenon thickness is 1/3 of the total thickness of the workpiece, making the shoulders' thickness equal to the tenon thickness, or I can glue up the entire leg extra large and then cut down the shoulders to get to the final thickness of the leg. If I do it this way the tenon thickness will be about 1/2" greater than the thickness of each shoulder.
My big ?: What gives the mortise and tenon its strength? Is it the thickness of the tenon inserted into the mortise pocket, or is it the width of the shoulders, cut square and glued under pressure to the mating piece? If someone can say with certainty I am overthinking this, I would appreciate it.
