Smallish end table
bowman
Board of Directors, Webmaster
Neal
Or maybe it's a stool? About 19" high. 11x16 top is a hunk of ambrosia maple. I used the bandsaw (with resaw blade) to scoop away a portion of the underside of the top, as a design element. Legs are laminated, then rough cut the tapers using the bandsaw then finished off with a template bit at the router. Mortise/tenon joints were glued to attach the legs to the slab. Will be finished with General Finishes Performance semi-gloss clear.
Wilsoncb
Williemakeit
Looks great, I love when simple design elements come together so elegantly. Size depends on the use. If it’s going next to a couch with lower arms, it’s perfect.
