Sliding Pantry Cabinet Shelves
zdorsch
Zach
I’m looking for input in sliding shelves for a pantry cabinet. Originally I planned to build the cabinet with fixed shelves, but realized how difficult it is to find things in the current pantry, so sliding shelves seem to offer a solution. Something like this image pulled from the web:
Has anyone used something like the above? Wire shelves seem to offer the benefit of letting light through and I don’t have to build them.
Henry W
Henry
We have wooden sliding shelves in our 'pantry', very much like the pic you showed, but spaced a little closer together. Spacing of course determines what you can store on them, so it is great to have:
- a few shallow ones near the top (cans stored there - pretty standard height),
- one at least for height of bottles (think spaghetti sauce or salsa, or salad dressing) and
- at least one (lower one) that will hold taller bottles (olive oil). I consider them perfect for a pantry.
Just me, I have not had/used wire shelves, but I think I prefer wooden shelves
Kits are available for such things. Can't point to a link, but my contractor provided a few more kits when I asked for them - in case I wanted to add sliders to specific locations (we do, but I haven't done it yet)
I built some for storage of pots and pans in the lower cabinets on each side of our stove. They look very similar to the ones in your picture; I made mine with 8mm Baltic Birch plywood about 1-1/2" high with finger joints on the corners and 6 mm BB plywood bottom in a rabbet brad nailed in place. I used full extension drawer pulls on blocks set to allow them through the cabinet face frame opening. Been in use for about 12 years with just a few coats of shellac on them.
We bought wire rack shelves at Lowes for canned goods, flour, sugar - they worked out REALLY well, I pulled the one for spices and "pouches" as they fell through the wire shelves, no matter if I lined the bottom, they found their way out! (in hindsight, I should have built a box to put inside the wire basket.)
Willemjm
Willem
I make these often for a cabinet shop who outsources their drawers. It is a shallow drawer box on slides closed with a cabinet door using zero clearance hinges. I use Blum soft close for both slides and hinges.
We have two in a lower kitchen cabinet, but not a pantry cabinet. I don't know what brand the slides are but they operate smoothly.
zdorsch
Zach
Any recommendations on where to buy hardware?
I’m leaning toward adjustable wood shelves with a sliding drawer based feedback that wire shelves have the “stuff falls out” issue!
zdorsch
Zach
Are you using this setup from blum?
With this bracket?
Willemjm
Willem
Ouch t
With this bracket?
Ouch, that is expensive but will work. Looks like the brackets are included in your first link. I purchase wholesale on a business account, that will be around $26. Just remember if you have normal cabinet door hinges and you mount the slides face-frame the drawer/sliding shelves will hit the door hinges. You need zero clearance hinges for the doors. Ping me and I will send you the Blum part numbers.
zdorsch
Zach
Ouch! Is right!
I’ll probably use the wurth soft close slides at $9.65 for the 21”. They seem to operate smoothly and they’re heavy.
Thanks for the tip about zero clearance hinges. I looked those up, but I’m leaning toward butt hinges for the space. With inset doors I’m concerned I’ll lose some shelf space if I use the adjustable concealed style hinges or run the risk of pantry items hitting the hinge.
gritz
Robert
We got chromed metal ones at The Container Store on a 20% off deal. We love them. Cheaper than the materials to build using 100# slides and maple ply to match our cabinets.
zdorsch
Zach
Which chrome metal ones?
I may be missing something, but the only chromed metal organizer I found was a two tier for $69:
Danny Batchelor
Danny
Guess they don't have them now. Maybe that's why they were on sale a couple years ago. Ours were 20" wide
Perhaps you could pull one of the shelf’s out and take a pix further back and from one side.
