Simple cabinet making question
lwhughes149
Lorraine
I have made a cabinet that will have slides for the drawers. The faceframe give me a 1 1/4 inch space for a spacer where the slide will be attached. My instructions that I am following says to use a 3" wide board for the slide to attach too. why would 3" be so important? The slide is about 1". Can I say make the width 1 3/4 inch? Thanks Lorraine
3" is not required, but does provide a stronger base that won't twist -- if you use the 1-3/4" width, just be sure to attach it securely to the cabinet sides (glue and screws). Mount the slide in the center to allow for adjustment up and down.
lwhughes149
Lorraine
If my spacer is about 1/16th greater than the faceframe could that be a problem? I have 1" poplar and 2 pieces of 1/4 birch.
RandyJ
Randy
Lorraine, Knowing what a perfectionist you are, if you decide to thin that stock, you are welcome to use my planer or jointer...
Take care,
