Thanks for the come-back, Ethan.
I seem to recall a similar problem a year or two ago. One of the responses was that my ISP had a problem and was not connecting to this site correctly. I contacted the ISP and the problem seemed to have gone away. As I recall, it may have been you responding at that time. Maybe it was some other technical expert at your end.
Could the same thing be happening now?
Sorry for the delay, I needed some time to gather some connectivity statistics.
I can't speak for more than about 48-72 hours ago, but starting about that time I have seen some glitching on the site (but this glitching and slowdown is very random and does not affect any specific page more than another).
There is evidence of congestion and occassional packet loss within
Cogent's backbone (a major internet backbone provider), which serves a backbone that is common to the connection between the NCWW server (in Texas) and your provider (ATMC), as well as between my own servers (Charter Business) and NCWW's. The packet delays and occassional drops will sometimes result in a page that takes longer to load and render, sometimes considerably more so if you don't just go ahead and reload, however, like I said above, it is very random and can affect any page on the site, so it is not limited to login.
If you're having issues only with login, then the issue is likely unrelated and unique to your computer or connection. However, I can only test up to your provider's DSL cloud router (I'm assuming you are a DSL customer based upon their router's name), I can not test the actual connection between you and your ISP (namely, your DSL line).
If you suspect issues with your ISP connection, you may want to visit
SpeedTest.net. It is best to run this test from a wired network connection to avoid possible slowdown and reliability issues related to a WiFi connection clouding the test results. As a residential customer, you can consider the test successful if the test results show uplink and downlink connection speeds of at least half your subscribed (contracted) bandwidth (e.g. if you have a 3Mbit downlink, 1Mbit uplink, then you want to see speeds of at least 1.5MBit/0.5Mbit -- or 1.5Mbit/500Kbit). If you fail this test the first time, try it at various times throughout the day to rule out peak use period congestion. If you continually fail the test more often than you pass, then contact your ISP to have them (or your telephone company) investigate possible line quality issues.
