My neighbor wants to build a storage shed (about 10' x 10'). He asked me to do a rough estimate on costs but I have a couple questions on materials. If this goes well, I will also be building something similar (but probably larger) for myself:
#1: Some have posted they used Hardi Panel (Lowes is one source). Did you sheath under it? and does it require special fasteners? Other option would be T-11 or RB&B wood panels, all within a $1 or so of each other. If the Hardi panel requires sheathing, then cost of it will raise total panel price considerably. The maintenance factor would be in Hardi Panels advantage, and cost of primer/paint for the wood panels would probably be equal or more than OSB sheath. At present, no inside panels/sheetrock is planned.
#2: Flooring: I plan on 16"oc 2 x 6's for the base. The difference between Advantech and pine sturdifloor T & G is about $2 a sheet. Which would you use, or would you just go with the $12 sheet OSB subfloor ($6 to $8 cheaper per sheet; $24 - $32 cheaper for the 4 sheets required).
#3: Would you use OSB for the roof? Coming here from FL and hurricane coast, I am prejudiced against OSB, but that is what's on the roof of my house. He is considering a Gambrel roof. Cost difference would be $25 - $30 between OSB and 19/32 pine.
Any advice appreciated.
And yes, I will be helping on the build. For free. (Hey, he's got a kegorator and a man-cave ccasion1 but also is a right fine person who helps others for free).
