I recently acquired a Delta 50-850 single stage dust collector. The unit is basically new, never been setup or used, but has some cosmetic wear from sitting in garage storage for many moons but for $100 I snatched it up. The problem is shop space is limited. So help me with some questions. This space is largely for hobby and I am doing small projects or one larger one at a time due to space constraints so it won't be dust everywhere all the time and the garage door is often open to help increase space by rolling tools outside for workable space.
1. My thought was to mount it on the wall, on studs, due to space constraints and not use the bags it comes with. Run an line for dust/debris to push down to a collection bin directly. Will this be an issue without a dust bag? Would finding a way to incorporate a cyclone system like a dust deputy be beneficial enough to sacrifice the space for it? My intent to also get a ceiling mounted air filtration unit as well.
2. Ducting in the 2/3 of a single car garage that I am limited too. My thought is to run the bulk as 4" PVC at ceiling level and then reduce down to the appropriate sized flex hose at tools that need it and 4" flex hose for just my table saw since that is the only full sized dust port I have. My understanding is gates near where the flex connection will go, is that accurate? Are plastic gates sufficient or will it require metal? The dust collector is 1.5HP.
3. Static mitigation. While I may not need this, I want to have it since flex will be incorporated and static can still be a potential issue. What is the "best" way to attach the static line to these tubes? Would metal flex clamps along the length with the ground work to avoid drilling into the tube? Is connecting a ground to the flexible metal clamp at the joints switching to flex sufficient? What would the actual ground line be connected too? Would that be the metal base of the dust collector since that is grounded through its power cable?
I understand some of this has been answered and there are chats about it. Mine does have a slight variation since I don't want to setup the large dust collection in the traditional fashion. Thank you for humoring me.
