For context - I bought the two compressors referenced in this thread:
http://www.ncwoodworker.net/forums/showthread.php?t=48015
The larger unit, a tank belt driven unit from Sears with no apparent model number shown, seemed to require a new pressure switch. The motor did not cut out before the safety valve released the pressure.
I have since installed a new pressure switch; it cuts out as expected at the stated 125 PSI. However in order to get the pressure to that 125 PSI, I had to hold in the safety valve. I did not try this with the initial pressure switch. It now seems to me that the initial problem may have been a mismatch of this pressure switch and the safety relief valve (or a safety relief valve that let go too early).
So the question is - there seems to be a lot of choices at a place like Grainger. If the pressure switch is set for 125 PSI max, what pressure should the chosen for the safety valve? The Grainger tech team just suggested a 150 PSI valve. Does that sound right to you?
Henry
Henry
