Router Bit question
TenguWoodwork
Kelly
Hi Woodworkers,
So I think I'm about due for a question. This one involves trying to simplify/ speed up my bokken (wood practice sword for martial arts) production. I'm curious if anyone knows a router bit that gives me an ellipse similar to the picture (insert, bottom left). The key is the ellipse, as round-overs don't give the right feel.
The commercially available bokken seem to route the cutting edge and handle identically, then route the back edge with angled bit.
My current process is bandsaw a blank, route the back edge of the blade, and block plane/spoke shave the handle and cutting edge. I want to reserve hand-carved for special pieces.
Approximate dimensions: 1"w x 1.25 - 1.5"h x ~40"l
Woodmolds
Tony
I think the bit you're looking for is a "Table Edge Router Bit" of the Thumbnail variety. Google images "table edge router bit" MLCS bit #'s 8558-8560 should get you close to the bottom left inset picture you posted.
Tony
Alan in Little Washington
Alan Schaffter
Two solutions-
1. Typically, you would use two different roundover bits and use a plane, draw knife, or scraper, or custom made scratch stock to smooth the transition where the two curves meet.
2. Have a router bit or shaper cutter custom made to your desired shape. Many companies will grind your profile for a decent price
I assume the bokken is curved and not an optical illusion. If so, off-center turning is not an option.
