just trying to be faithful to the original material (glue and scraps). you know, preservation and all...OR, if you have some scrap material laying around why not route out the offending area and glue in a patch. Then you can reattach the leg and move forward.
Also could use Ramen noodles or oats, both natural fibers and not much good for anything else.just trying to be faithful to the original material (glue and scraps). you know, preservation and all...
I was trying to go from point A to B fast and cheap.just trying to be faithful to the original material (glue and scraps). you know, preservation and all...
I might not be typical, I always have some WEST SYSTEM epoxy on the shelf. For me that is the fast and cheap solution.And
Can't speak to Ramen noodles, but I go through a lot of oats!Also could use Ramen noodles or oats, both natural fibers and not much good for anything else.
Yep!I might not be typical, I always have some WEST SYSTEM epoxy on the shelf. For me that is the fast and cheap solution.
Understanding if you don't have it, the price of entry is steep for a job like this !
Glad I could help. I hope the repair lasts longer then all of us.Bought the 52" Unisaw, with mobile base, in 1994. At this time I had never even turned on a TS. So bigger had to be better, right. Soon realized an out feed table was needed. Because of limited space, and skill, I bought the Delta out feed table with folding leg. Worked just fine until I moved everything around and found I only needed to drop the table half way. Did not think about the stress on the connection. The 4 screws finally pulled out.
Hence my post on solving the problem. The particle board issue caused about some doubt for me.
I decided to move the TS a little so I would not need to drop the out feed. I took statics in college, yes I can remember that far back, so I figured with the sideways stress removed I could use the simple solution offered by Richard, Graywolf.
I routed 2 rectangular holes, cut 2 pieces of walnut and glued them in place. I attached the leg to the bottom of the out feed table, and reinstalled the out feed table. Saved about 1.5 hours in travel time and did not spend any money.
