Best source would be uscomposites.com I am thinking their 150 resin would work well for you. Definitely do not use the resin found at either big box stores, they will cloud over within the first year.
What is your type of river table that uses pigmented epoxy poured into some carved out profile? How do you do the profile before the epoxy pouring?
I use West System epoxy exclusively. Usually the 105 resin and 206 hardener but there are other hardener choices to use with the 105 resin.
https://www.youtube.com/watch?v=ZwCVG-VA-ck
While I agree West System offers a very good epoxy system. The West System quart size kit cost approx $70, while the USComposite quart size kit is $23 and is "good enough" for an interior table
That's a good price. Do you use it for your carbon fiber boats?
I'm not sure where you got $70 for West. A quart of 105 resin is $35 and a pint of 206 hardener is $19.45 and the mixing ratio is 5:1 respectively. That's a lot of mixed epoxy for a single pour. Not a big deal for me though.
We use epoxy resin from USComposites for all sorts of laminating, ranging from carbon fiber, fiberglass and wood.
The West System price of $70 came from Amazon. I did a little rounding actually with shipping it is $73
But just to throw a curve ball, the more I think about this application I believe a casting resin would be a good choice and it would save you some $.
Compositeenvision.com sells the Silmar 41 clear polyester casting resin. One gallon with hardener is only $68
