Post Covid Workshop - List attached - SOLD OUT
Phil S
Phil Soper
I got my old crystal ball. It said everybody is anxious for a workshop and that June 19 was the right day.
Mike (Pop-Pop) and I have been planning this workshop - in full transparency, Mike has done all the work. He has designed and prototyped a fabulous bench top criss-cross vise. He will be the guest instructor while I will just be the host
Here are some photos of the prototype - mounted in my much more expensive Benchcrafted criss-cross vise. Mike's vise is smoother
Mike will make the metal parts for the criss-cross prior to the class. Each student will need to provide there own 8/4 wood - we will forward an exact list of part sizes at a later date. I will have my equipment preset with jigs to speedup the operation, plus I will serve lunch
We have room for eight. Cost of the workshop is $75 which includes all the mechanical parts plus the cork/rubber facing that are not shown above.
Please respond via this post or PM and I will create the student list
Obviously, if my guess at a safe date of June 19 is wrong we will shift it
Happy Thanksgiving
Student List
1. Fred P
2. Johnny R
3. Michael Mathews
4. Burns - RedBeard
5. Donn - DRW
6. Richard - Graywolf
7. Danny Batchelor
8. Phil's guest -
JohnnyR
Looks like another well done vice by Mike. Is there a use of it other than changing the orientation 90 degrees and/or adding height to your work? Maybe answered my own question thinking about my old back bending over for detailed work.
Michael Mathews
Michael
Phil, Mike, What does the vise look like mounted to a bench? I might be in for this workshop but need to see how easily I can adapt it to my existing workbench! Thanks!
pop-pop
Man with many vises & whackers
Here is my vise clamped to the bench using C- clamps on the bracket. My experience has been the C-clamps hold the vise much more securely than F-clamps.
pop-pop
Another option is to make the bracket wider and bolt through dog holes like this:
In round 3/4” dog holes, I use 1/2” carriage bolts, washers, and wing nuts. Those wing nuts are large enough to be able to hand tighten enough to secure the vise.
pop-pop
Yes, you did. The primary advantage is raising work to elbow height which is ideal for many tasks.
Another feature is a sort-of quick release. The vise chop slides freely in and out with whatever slack is left by the position of the nut on the screw. The slack can be quickly taken up by giving the handwheel a flip and it will move 2-3 inches along the screw.
Phil S
Phil S
Phil Soper
And here is some photos of one clamped to my joinery bench. I like having it removable from the bench as sometimes I need the entire flat surface of the bench top.
Another great design feature of this vise is having the clamping wheel in the rear allow you to stand closer to the vise jaws
pop-pop
And here is another mounting option which can work well on large to huge assembly tables.
Here is a close-up:
pop-pop
Curious how is it used & what are the advantages?
First, it is a bench vise that can hold work pieces or act as a clamp for glue-ups.
One advantage is portability so you add a vise on a bench, picnic table, porch railing, or wherever. Another advantage is your work is usually at elbow height facilitating sawing, block planing, etc.
Phil S
Phil S
Phil Soper
Actually Danny you are number seven. The last spot is being held for a member I promised he could have a spot
