Porter cable omnijig information
skrewd
john
Hello, need help, I have an omnijig 77240 with most accessories but one, the 55165 mini box jig accessory. I have found the bar setters but can’t locate the template guide bushings or there size. If someone with the jig templates could measure theirs I could mill my own. In particular the g6, g6.1,g6.2,g6.3,g6.4, g6.5, and the g9. Also known as 24241,24142,24143,24144,24145 and 24275. I need O.D. Of each template guide even better any for sale, thanks John
skrewd
john
Service.net doesn’t know, porter cable customer service doesn’t know. Porter cable is basically gone, just DEWALT staff.
Roy G
Roy
John, check over on Woodcentral. They have world wide members and somebody may have what you need.
Roy G
John,
Sorry not to answer your question earlier, but I've been away from home for nearly 2 weeks and just had a chance to see if I had that kit. Indeed, I do and here are your data points from my set. The Bit is S0, which is a solid carbide two flute straight bit that measures 0.280" (7.14 mm). [I'll give measurements for the OD in the same order; inches and mm in parentheses]. Bushings: G6 0.468" (11.90 mm); G6.1 0.474" (12.07 mm); G6.2 0.479" (12.16 mm); G6.3 0.484" (12.30 mm); G6.4 0.488" (12.40 mm); G6.5 0.494" (12.56 mm); G9 0.335" (8.52 mm). The ID of the bushings is unimportant, but for reference, G9 has an ID of 0.296", enough to clear the S0 bit. The others have 0.410" (10.40 mm) ID's. If you need information about the other 2 pieces included in the 55165 Kit, the double stops, feel free to contact me.
Hope this helps.
skrewd
john
Can’t get into Fort Knox, can you post this there for me.
Hello, need help, I have an omnijig 77240 with most accessories but one, the 55165 mini box jig accessory. I have found the bar setters but can’t locate the template guide bus Hello, need help, I have an omnijig 77240 with most accessories but one, the 55165 mini box jig accessory. I have found the bar setters but can’t locate the template guide bushings or there size. If someone with the jig templates could measure theirs I could mill my own. In particular the g6, g6.1,g6.2,g6.3,g6.4, g6.5, and the g9. Also known as 24241,24142,24143,24144,24145 and 24275. I need O.D. Of each template guide even better any for sale, thanks John
Not available at ereplacement parts , they just redirect to service. Net, of porter cable, which doesn’t have it or know anything about it, not on eBay or amazon. Part of 55165 kit but just need the template guides.
skrewd
john
John,
Hope this helps.
Perfect, thank you so much , going to mill some right now. Thank you thank you
