Thanks for all the replies and advice. I have ruled out PVC, PEX, black and galvanized pipe. So I guess that leaves copper and air hose. Copper 3/4" "M" pipe at Home Depot was $1.50 a foot today and air hose at HF was much cheaper. I like the look and neatness of using copper but it cost more and I don't have any experience soldering copper so I am still undecided but at least I have narrowed the choices.
Thanks again.
I used 3/4" SCH 80 PVC, but I would recommend this..
http://www.rapidairproducts.com/
You can buy the components from Mcmaster Carr as well. It is cheaper than PVC, pressure rated, and easier to install. I'm using it in my next shop for sure. I'll probably pipe it in the walls for a clean install.
Good luck,
Has anyone used Type M copper for air lines ? It's not recommended for air lines. I've got about 200' and was going to use it as secondary air (under 60 psi) to blow off machines.
TIA
Ummm,,,Interesting product.
Has anyone here used this product?
Who doesn't recommended grade L for compressed air lines?
Here is what the Copper Tube Handbook says:
"Compressed Air—Use copper tube of Types K, L or M determined by the rated internal working pressures as shown in Table 3. Brazed joints are recommended."
Since 3/4" grade L is rated at 700 psi and 1/2" almost as much, I don't see why not! And you don't have to braze it either. See my earlier post for the link.
All my 175 psi air lines are grade M copper.
Alan,
Page 20 of the Copper Tube Handbook only has compressed air for use with Types K & L.
The rapidair system looks good to me. Have to think about it for awhile but possible Christmas request. I have been wanting hookups on both sides of the shop instead of having to run a long flexible line across the shop and I also would like to put a drop in the other garage. I used the calculator of their website to check airflow. They say you can get over 10cfm at only 40 psi through 100 foot of their 1/2 hose (3/8 id). They calculate over 25 cfm at 150 psi. My compressor will only supply about 5 cfm so I think it should be big enough for me, even with more drag from the flexible hose.
