It has been awhile since I posted anything regarding this built. As you can see, I am making progress. I have one pedestal completely wrapped in molding (the bullnose bit I was using chipped, a new one will arrive tomorrow and I can finish the second pedestal). All things considered, I am pleased with the results.
That said, I am having a problem (see second picture). The cross trees are mounted to the pedestal with a large mortise/tenon joint and then screwed from the backside of the cross trees into the tenon. I countersunk the screws and then plugged the holes using a thin film of titebond on the plugs. There are eight plugs and seven of then look like the plugs in the photo. What is causing this and more importantly what can I do to stop it? I can sand the stains away but with 30 minutes the stains reappear (this has been ongoing for two-weeks). I could probably drill out the pugs, but whatever is leaching has probably migrated into the cross trees.
Thank you for viewing
