I picked up a panel saw last week and am setting it up as we speak. I'd like to place it in a bit more of an upright postion than one usually sees with these, as that would give me a great spot for lumber storage instead of having largely dead space behind it. My concern with this is how to being sure that panels being cut will lay flat on the the saw. With the saw tipped back at the angle you usually see gravity does the work for you. With a more upright position the panel is a lot more likely to tip or shift as it's cut. I was thinking of placing a vertical track with a hold down clamp on either side of the saw track to take care of this. This would allow me to quickly and easily clamp the top edge of the piece, and I think this address the issue sufficiently so long as the board is not badly bowed.
However..
I couldn't even begin to count how many times I've started a conversation with "Well, it looked good on paper...". Given that I have little practical experience with this type of saw, there's a reasonably good chance of this happening again. Before I go to the trouble of mounting the saw and adding the track and clamps, does anybody have any thoughts on my plan? Any other concerns I may not have thought of, or any other suggestions?
Thanks!
However..
Thanks!
