I'm in the process of making a dresser/changing table for my son (due in January). I decided against plywood and I'm using solid cherry edge jointed to make one large panel for the top and sides. For the top and sides I have four boards about 5 inches wide that I've joined and glued using biscuits. When I glued everything up, I'm noticing that there is a small cup in the middle of the panel. I'm suspecting that when I clamped everything together I may have put too much pressure on the boards causing the middle of the panel to cup a bit.
What tools/techniques does everyone else use to prevent this? The cup isn't too bad that I think it will affect the project too much (although putting in the drawer rails should be interesting), but I would like to find a way to eliminate this altogether in future projects.
