A few weeks ago I decided to cut some brackets on my band saw. After I skinned my knuckles and wore a callus on my hand trying to tension the blade I started the saw and in about 10 seconds I smelled burning rubber. The sound wasn't quite right either. My first thought was the belt. On inspection it looked fine. I opened the lower access door to find the tire was all but off the wheel. I tried unsuccessfully to re-seat it but it kept creeping off.
This little inconvenience led me to my personal band saw bible, the Iturra Design Catalog. There are several books on how to use a band saw but there isn't a better book on all about band saws, in my opinion. I searched the archives here to get as much information as I could on replacing tires and recommendations on different products in addition to the catalog. It was the majority opinion that when replacing a worn out tire you should replace them both. In addition it seemed to be the preference to go with urethane instead of rubber.
As long as I was going to need tires, I investigated the solution to my tensioning problems. First, I needed to replace the spring and second I wanted to replace the knob on the rod.
I knew I could get the tires and spring locally but there was no substituting the Iturra Spinner 3 Tension adjuster! My hand is worth it so I ordered one.
I bought the blue urethane tires from Woodcraft and the bright yellow high tension spring there too. I'm not sure that the tires were the best choice because they are pretty pricey, sold individually and although they state they fit Jet and other Taiwanese models, they are about a 1/4" narrower than the wheel on my saw. I may have done just as well to have bought a packaged pair of another brand for about the same money.
In all I spent about $ 110.00 upgrading to these improvements. I'm happy with the result of all the replacements and tensioning the blade now is so fast and so much easier with the spring and rod, I wish I had done it long ago.
I have pix of the new improvements that I'll post in my gallery when it returns.
Thanks for reading.
Thanks for reading.
