I am working on a new bench and I have the shell complete. The shell is just a bunch of 2x4 studs. The legs are three that have been jointed, planned and cut to length and then glued together and the main cross pieces are the same. It is mortise and tenon and then screwed together. I plan on adding either drawers or cabinets in the center or possible both. The questions is what should I use as a top. I had though the same 2x4 studs glued together but that will be about 20 studs, but I am not sure if this will be to soft of a top. I could also use a few sheets of plywood glued together, this would be nice and flat and harder.
Any suggestions?
Any suggestions?
