Need some help
sazdaman
Well, I guess it's time I reach out for some help on this one. I'm currently in process of making a bass guitar. It's close to being complete, however I have two routing cavities that still need to be routed out that I may need some help on. The bass is not flat, it has a radius to it. So just putting the router on top will not suffice.
Originally I used a 1/2" straight bit with a bearing that rides up against a template of hardboard. This doesn't work because the bearing eats into the template.
So what should I do?
MarkE
Could you make your template from 3/4" mdf and then shape the underside so it matches the radius of the guitar? THat would give you a flat top surface for the router base.
Mark Gottesman
If your bearing is eating into your template, it may not be rotating properly. Just a thought on something to check.
You could drill out the majority of the cavity and finish with a chisel or a router plane.
