I coated a table top with mirror coat following the instructions. Did the initial seal coat, waited a full day before applying the flood coat. Applied the flood coat, spread it out with a paint brush and waited about 10 minutes. Then used a propane torch about 6inches above the surface to remove all visible air bubbles. I then walked away to let it cure. Today I went to check on it and there about a dozen or more air bubbles that created bumps on the surface. They are not large, just raised above the rest of the surface which is otherwise smooth. While I can find tons of information on systemthree’s website on how to remove air bubbles while the epoxy is still wet, I’m not having much luck finding information about how to repair bubbles in cured epoxy. The closest thing I can find is a video on sanding and polishing a damaged surface. Do any of you have any experience with fixing this issue?
