When should I use mineral spirits over traditional thinner? I just invested is some really good brushes and was told to use ONLY mineral spirits for cleaning the brushes. Is that true?
I use brushes for just about all of my finishing. I don't have a spray booth so the brush is the method for most of my finish work. As others have said, a cloth rag is better for some finish applications.
I think Mike Davis hit all the big points very well. I think Mike is the first person to mention finishing up the cleaning of oil based brushes with a light oil coat. To clarify a little further- After cleaning my natural bristle brush with paint thinner I dip my brush in thinned out linseed oil. I thin with turpentine and wipe it down pretty well. After a week the brush will feel a little sticky but not hard. Before use, I soak and clean in MS or turp. Ready to go again. Why the fuss? Some of these brushes are very expensive and you want to keep them in top shape.
To add one more brush to the specialty mix I would insist on a dedicated shellac brush. This brush gets a different cleaning schedule. Because shellac is "reactivated" with denatured alcohol, I don't clean is entirely. I can leave some shellac on the hairs and its OK. Before use, I soak it in DNA and shake it out. I always get DNA up to the ferrule of the brush to prevent finish build up high on the hairs. This has worked for me.
I NEVER use my varnish brush with shellac finishes. The oil on the hairs effects the flow of the shellac which is very thin.
So I have 3 brush categories: natural bristle oil, natural bristle shellac, synthetic bristles for water based paints.
Traditional thinners. I'm not sure what you are referring to with traditional thinners. To clean oil based varnishes you can use mineral spirits, turpentine, naptha as a start. I keep these around for their different dry time characteristics when thinning varnish mixes. They are also good cleaners. It seems like the MS is the cheapest so I use it most of the time. If you clean with MS and pour it in a jar the impurities will fall to the bottom of the jar. I then pour off the clear MS on top in a clean jar and reuse it over and over. The crud on the bottom can be scraped out and left to dry out on a piece of glass before disposal.
Jeff asked: MS(paint thinner) vs turpentine. Not being a chemist as I know he is, I'll touch on the empirical differences while using the 2 solvents and leave the ingredient differences to another person.
MS dries faster than the turpentine as a rule. Turpentine has a strong smell that some folks do not like. For cleaning I don't see much difference really. If I see a gallon of turpentine that's cheaper than the MS, guess what? Turp.
Lastly, these solvents I have highlighted as extremely volatile liquids. Be extremely careful of where you store rags and materials to prevent a fire.
later
