Metal duct question
rherrell
Rick Herrell
Okay, I took the plunge and ordered all the material to build my new shop. A 24x28 metal bldg. with a wood floor , 2 roll up doors, 1 man door and 4 windows. I've decided to go with a 2hp Super Dust Gorilla with metal ducting for dust collection.
My question is ,has anyone heard of Duct Inc. in Winston-Salem? They have some good looking duct and it's close by. If not , does anybody have any suggestions? Looking forward to your input.
Thanks,
Rick
T
toolferone
User not found
If you found a good local supplier, then I would use them. Just be aware of the radiuses they use. Some are tighter then you might want for dust collection. That being said, you could save lots of $$$,time and headaches by using PVC. I have a 3hp cyclone and I am using 6" S&D(thin wall sewer & drain pipe) PVC. It is very easy to work with, light and cheap. I used a local supplier for the 10' pieces and I used http://www.mcmaster.com/ for all the fittings (much cheaper then my local source). the link below shows some of my system.
http://www.dreamshopwoodworks.com/cyclone.htm
Steve D
Member
Steve DeWeese
I went with metal duct using standard HVAC components. I used Y fittings and have very few 90's. In retrospect, I would echo the PVC S&D suggestion because it is easier to work with and also quieter. The only reason I went with metal was the large cost differential in fittings. Pipe was cheaper but the fittings were double. I costed it out both ways and PVC S&D would have run another $250 in my application.
Alan in Little Washington
Alan Schaffter
Are you sure about the cost of fittings? Fittings are the killer no matter whether you go with metal or PVC, but the last time I looked S&D was still way cheaper than metal (good metal, not HD). Also, the last time I looked, Sched 40 PVC fittings were about twice the cost of S&D fittings- $10-$12 for an S&D 6" wye compared to $24-$26 for a Sched 40 6" wye.
I recently installed full metal ducting, and I can honestly say, never again. If I was going to go metal, I would break down and buy spiral pipe, otherwise, I would go with s&d. If you are good with sheet metal, more power to you, but I can say that I am not.
As the others said, check the radiuses and the guage of steel if you go with it.
rherrell
rherrell
Rick Herrell
I'm a sheet metal fabricator by trade for 35 years so when it came to dust collection PVC didn't even enter my mind. I guess I'll need to get a photo gallery and keep you posted on my progress. Like they say, no pics , it didn,t happen.
I'd also be glad to be of any help I can to anyone who has decided to go with metal ductwork.
Thanks for the input,
Rick
T
toolferone
User not found
Rick
Well that clears that up!:rolf: Just remember that you are working with negative pressure. The thin wall 30ga and 28ga snap-lock pipe can collapse on you. Look forward to the pics.
Steve D
Member
Steve DeWeese
Yes, I went with standard HVAC 6" Y fittings and they were much cheaper than S&D fittings. I caulked the seams with joint seal and taped the joints. They work perfectly well and don't leak. Being naturally cheap, I also made my floor sweep out of a 6" HVAC register boot. I cut the corners, bent 3 sides to form a flange, made a cutout in the front, screwed it to the floor and viola! a $6 floor sweep.
