Yes@mdbuntyn Is this what you are referring to?
Asking in general and that was just an example at hand. Agree on your point though and the Inch or so long “back” was sharpened to be flat regardless of its angle.My question to you pop-pop is that you are show an example of what appears to be a plow plane blade. So are you asking for in general use or fo that particular tool. The reason I ask is when I sharpen tools such as plane blades, chisels and alike, when it comes angles a degree or two one way or the other is negligible to the performance of the tool. I know folks do things differently and this has been helpful in seeing a wide verity of for the most part reasonable priced products to make our life easier and hopefully more accurate. So how accurate do we have to be?
Thanks Scott - I didn't go out and look (like I should have) so I didn't realize the angle gap on the acute side went to ZERO! that is just stupid!@Hmerkle Sorry, I am being unclear, maybe this is a better illustration of what I'm referring to. I am sure you have used these plenty so I am probably just communicating poorly.
If you have an angle of say 25+ degrees there is the angle formed by the two pieces you can stick something into, so either you set the gauge by closing it on the item and reading, or set it to a reading and look for daylight. When the angle is too small that gap closes up and the best you can do is what I have in the 2nd picture (10 degree angle) which doesn't feel anywhere near as positive/accurate of a reading, compared to things mechanically touching or seeing daylight through a gauge. It's fine for getting kinda close though.
I searched for over ten years to find mine at a price I could justify. It is an older version but in nearly perfect condition.I think the best answer (for a direct measurement reading) is @Mike Davis 's solution of a (Starrett or competitive brand) universal bevel gage.
But again, you may be paying for precision that may or may not be "required". Even used those can be VERY spendy!
